2007 Yamaha Rhino dash display not working
illinois1
    • By Clydaho
      Any other ideas?
      Thanks for any help,
      Clyde
    • By Topendcol
      Col
    • By Uglyside38
      Has anyone had any luck converting an older quad from a 7 wire CDI to the newer (and cheaper) 5 wire CDI?
      I have a 1988 Suzuki Quadrunner and I believe the CDI is on it's way out...🤦🏼‍♂️ A used CDI from 1988 goes for $250-$300 on the bay...and that's when you find them. The Chinese CDIs for the 1990 and up quadrunner are only about $40. I have read a blog from a guy who says it's possible and that 2 of the wires can be omitted if the rectifier is a newer one also. Any experience with this would be greatly appreciated!!!🤙
    • By That229Yamaha
      Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind  the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
    • By beast6228
      So the other day I picked up a Lakota 300, it's going to be a new project for a bit, the engine is super clean and so is the frame...luckily the VIN was intact.  However, it is the missing the air box (the one that holds the filter) but it does have the air chamber that goes to the carb.  These air boxes seem to be pretty pricey, so my question is has anyone had any luck running a pod filter on theirs and if so, what kind of jets are you running? The carb on this one is a Keihin CVK, I have yet to pull it off and inspect it.
