Hello¡ i need help my warrior dont start
somebody tell me the specs to stator
it has spark but dont start either pop nothing
I CHECK TIMMING AND APPEAR BOFORE T I DONT KNOW IF ITS CORRECT OR NOT
COMPRESSION 150PSI ....now i have checked the resistance in 4 wires in the stator RED & WITHE=219 OHMS AND THE OTHERS 2 WIRES GREEN STRIPED YELLOW=1195 AND YOU HAVE REASON DIRTDEMON IT HAS A PISTON J.E OK I DON'T HAVE THE SPECS THEN WHAT I DO??
HELP ME¡¡¡
Edited by JAVUTV
MORE INFORMATION
What do you mean, you checked the timing and it appears before T? If the machine sparks way before TDC, then you probably have a sheared flywheel key. Another thing to check is the vavle lash. BTW, 150psi is pretty strong for a Warrior, you might even have a high comp piston or a slightly shaved head. Make sure you are using premium unleaded fuel.
    • By realpilot
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By OldATVowner
