ok ive been going crazy the last few days trying to figure out whats wrong with my predator! since i leave the bike at my dads house someone there left the red kill switch on. we bought a new battery and put it on but that didnt work and we tried 20 minutes later and it worked! we disconnected the positive wire to the battery and left it. the next day i tried starting it and it wouldnt do anything! no noise, no light, nothing! any ideas? :aargh::realmad:
    • By LMI
    • By tds7
    • By Louznmemind
      I know this is a stupid question but here I am.. I'm wanting to have the ability to disable my taillight/brake light on my '96 Polaris Xpress at will, it comes on with the key and there are times I don't want it to illuminate. I have basic wiring knowledge and I'd like to put a toggle switch to disable it. I'm not sure of the wiring setup on this thing, can I just use a toggle switch on the ground wire to kill it when I choose? Can someone clarify which wire I need to work with and the easiest way? Excuse my ignorance yall.
