Hi everyone. My name is Michael, I am from a small town around Central Pa. I recently bought a 2000 Arctic Cat 300 4WD with a couple problems and happened to find this place, so far it seems really nice here. I think I will be sticking around for a while. :D
    • By tepin
    • By randyoct
      Will the top end of a 400 fit a 366 the price is so much cheaper
    • By HHurks
      Hi to all
      Newbie here. Not new to ATVs. Look forward to learning a few new things and hope to maybe help some too.
    • By Jason39
      I’m having a issue with my choke when its on it runs fine when I cut the choke off the atv cuts off went to take the carburetor off and saw the choke plunger broke at the nut to screw it in could this be my issue? Do I just need to buy a plunger kit and put it on? I took the carburetor off and cleaned both jets anyway just to make sure and it’s still having issues staying on
    • By spigmef
      I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
