I finally got a new quad after going 11 years since I sold my banshee. I went and purchased a 05 YFZ 450 from a guy about 1 mile away from me that I found on craigslist. I paid $1800 for it. Its bone stock just like I wanted and is in fantastic condition. I took it out on the lake tonight and wow I did not realize how much I missed having a quad. So I now have a quad for my son and myself and now I have to find the wife one real soon as I think she put more time on the thing tonight than I did. Any ways if anyone is in south east Michigan and close to Oakland county hit me up I have the lake right out my back door and your more than welcome to come over and ride.
AJMBOY I will try to get some pics up tomorrow. Every time I got home from work this week it was to dark to take pics. But we will be on the lake tomorrow for sure. Its supposed to be a balmy 10 degrees so should be fun.
How do you like the YFZ compared to the Banshee? I'm sure the handling is way better on the YFZ, but it is hard to beat the snappy power of a good 2 stroke, and the Banshee was one of the best.
Well so far I am loving the YFZ but I have only had it out on the lake in the snow. And the 4stroke torque is amazing. I did love the banshee but I like the ability to ride out of any gear at any time with out having to keep the RPM's up all the time. I am also 10 years older and much lazier so that might have alot to do with my bias.
    • By TomJulio
    • By Callaway
    • By joezee13
    • By middlebrookgt
    • By Olchap
      Hi, I am new to  this forum and I am happy to be here.  I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is.  I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing.  I checked up near the radiator and found nothing.  Where else should I look?  See image below.
