i ride a 03 350 warrior im wondering if any one can tell me if i can fit a 650 ninja street bike engine on it
That would be alot of work my friend, just go get a bigger and better quad.:yes:
That would be a pretty tight fit and lots of fab work. Plus the Warrior has such a small wheel base it would be hard to keep it on the ground. I would look into a bigger quad
I agree with Stoopidbot1:skeptic: a lot of fab work Would be interesting to watch this build if you do it !!
Be a lot of work, but would be a pretty cool project. If you go ahead with it, it would be very interesting to see some pictures of your progress. Would for sure be a one of a kind. Let us know if/when you decide to give it a try.
I agree with the never say never thing. When I started building my 250R/CR500 hybrid, I got lots of negative feedback from forums that I was posting on and from people that I knew that apparently know everything, but have never built anything with their own two hands. I did it anyway ofcourse, and am glad I did, it isn't perfect, but it was cheap, and I have yet to see a daily rider type machine that can hang with it, especially when you consider the $ to $ comparison. I have less than $2k invested in this thing, and I can eat $8000 Raptor 700R's for lunch all day long. That being said, it is alot of work to do a motor swap of any kind, especially when you are trying to wedge a 4 cylinder street bike motor into a small quad frame. I would also agree that the Warriors poor handling charactaristics are not going to be favorable to all the power that the Ninja motor is going to put out. But there is a solution to every problem if you are determined and skilled enough to get the job done. If you really thing you can make it work, I say, why not. If you think, even for a second that you don't have the necessary skills, or aren't willing to make the effort to do things right, I would not even consider the idea. If you do decide to do this, I would very much like to see a thread started in the project room so we can all see this beast in the making. This would also give you a platform on which to ask others for ideas if you need. Good luck, whatever you decide to do.
Edited by DirtDemon
    • By digrig
      Hey everyone,
    • By Rick Shropshire
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
    • By shorty
      FYI: I used a volt meter to test the stator/rotor output. Pulled the plug on the rectifier/regulator to access the 3 wires coming from the stator. The other 2 wires are 12v pos and negative so easy to identify the 3 stator wires, which are yellow on my Kowhockey. You should see around 30v AC not DC coming from the engine stator. Test all three wires to EACH OTHER not ground. Remember the stator puts out AC like an alternator. The rectifier converts the AC into DC to charge the battery. On my case the rectifier/regulator was bad, obvious because the 3 stator wires showed 30v AC
    • By jatho
