Have a high heat issue on the right side panel on my 2021 cforce 400, as complained about by the wife.
My heat gun shows after 15 minute ride in ambient 91 deg temps; 690 degrees on front end of muffler close to entry pipe and 375 on exit side of muffler. The right side plastic (where wife's leg would touch) was showing 175 degrees. This is rediculous!.
As I understand the muffler has a built in catalytic converter which obviously kicks off high heat particularly at front end of muffler, but the heat is atrocious.
What is everyone doing about this problem? Is there a replacement muffler to eliminate this issue?
Hi. I just bought an lt230 1993. Ive started buying parts for a full rebuild. But somehow beskepedal has been removed and pegs welded to where They are supposed to be screwed. I was wondering if anyone have one and Could measure how far out the pegs are. Like the peg the brake is put on and then peg outside of it. And the one lower down. So i can recreate them.
