Im having some issues when putting it into gear( High specifically ) It doesn't seem to go in all the way and makes like a grinding noise and won't engage. I have to take back out and try again. Seems to happen if the engine rpm's are revving. Wondering if anyone else has had this issue or similar, and what I can do about it. I only have 200 miles and 26 hours on the machine just doesn't seem right. thanks
This happens alot when you rev above idle and try to change gears. Two common problems are if your idle is turned up too high from the winter riding season (carb) or if the autochoke/efi is still set to let the bike warm up.
I believe the 500 is still a carb model if so then adjust the RPM.
Adjusting Engine
RPM (Idle)
NOTE: The idle RPM is not adjustable on the EFI
models.
To properly adjust the idle RPM, a tachometer is necessary.
To adjust idle RPM, use the following procedure.
NOTE: The idle adjustment screw is located on
the right-hand side of the carburetor.
1. With the transmission in neutral, start the engine
and warm it up to normal operating temperature.
2. Turn the idle adjustment screw clockwise one turn
past the recommended RPM setting; then
The other thing would be to check that the pod reads the correct gear and not displaying an error.
Here is a link to the service manual:
http://www.quadcrazy.com/atvforum/arctic-cat-atv-forum/8558-need-service-manual-here-they.html
Edited by swampcat07
Added step by step for checking idle.
The 2005 auto carb has a extended throttle adjustment. It will look like a rubber hose about 4 inches long with a knob hanging off the back side of the carb.
Turning clockwise will increase rpm, Counter Clockwise will decrease rpm.
Why is it doing what is doing.
When the engine is at it's proper rpm the Centrifugal Clutch is fully disingauged and the is no ingaugement of the bikes drive system. As engine rpm increases the Centrifugal clutch starts ingauging the drive system, the belt starts rotating and the trans starts turning.
The transmission on these bike are a streight gear geartrain and the there are no synchronizers in the system. So with the rpm's raising everything in the trans is moving and your trying to a move a non-rotating gear into a rotating gear. With out a synchronizer the gears will never mesh.
Why has your engine rpm gone up? More than likely it is a varnish build up in the idle curcuit. The varnish has restricted the idle curcuit causing the engine to be running leaner at idle. The lean condition causes the engine to increase rpm.
I would recommend running a good fuel system cleaner in gas. It is also a good idea to run a good fuel stablizer designed to work with ethonal. Todays gas sucks.
  • 2 years later...
I have a 08 arctic cat 500 an mine did the same thing just took it and got it fixed what it was the teeth on the gear had broke off
    • By canamKID
      20260711_150338.mp4
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By jeffrocdx
    • By digrig
      Hey everyone,
    • By alexwv1863
      I'm currently working on an 04 Suzuki Eiger 400 and ran into some issues. Main issue being it's really hard to start. Once I get it started, it runs bad. Sounds like it's missing, which I'm pretty sure is an idle issue. It's not my 4 wheeler. I'm working on it for a buddy. Someone started working on the original carb and 2 jets were missing when I got it to work on.
      So, I ordered a new carb. To get it to run, I had to adjust the throttle screw on the handle bar almost all of the way out. Even doing that, it still sounds like it's bogging down and missing.
      I did put a gas filter on it, which I'm questioning whether or not that's the issue and it's not getting enough gas like it should. The petcock only has an On, Reserve, and Prime option. It also has 2 ports. I guess I have the hoses hooked up right. There's no way to shut the gas off completely, and also it looks like there's no gas getting thru unless I run it on Prime. Reserve drips gas. I'm going to take it apart today and clean it. I'm also going to take the jets I need out of the new carb and put in the old one.
      I don't know what all this person did you the 4 wheeler before I got it. There's odds and ends missing that I've noticed so far. What else can I try or look for? What could be the gas issue with the carb and petcock? The carb was completely off the bike except hanging onto the throttle cable. The diagram I found for the carb doesn't help me with hose placements. Any help, or questions would be appreciated. I can attach photos if it would be of help.
