I'm considering buying a 2000 Arctic Cat 400 4x4. The dealer I'm purchasing from just got it in on a trade in. The ATV has 4,100 miles on it. The body is in great shape for being 11 years old. The seat is good and the tires are about 50%. The dealer won't budge from $2,500 and I think I'm getting screwed. The KBB is $1,800 for retail. What are your thoughts good or bad deal?
Sounds a little high to me but sometimes it's worht paying a little more for a machine that has not been abused and has been well taken care of. I would look around a little more and if you look hard enough you will find that machine that has been taken care of and for the right price, good luck!!
    • By tepin
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
