Join Today, It's Simple and FREE!
1997 Sportsmans 500 - drive belt pulley grinding on housing
By
Deerslayer, in Polaris ATV Forum
Similar Topics
By Scott Sirr
I need to figure out how to clean/fix or replace my neutral switch assembly On my 2008 Yamaha big bear 400 as generally the neutral light doesn’t come on when it is in neutral. To get it to come on I have to wiggle the foot shifter and hold it in just the right spot.
I have googled it and can’t find much on the 400’s. I can’t find a service manual online and the parts manual is super vague.
I think it is in the right side engine cover area, but not certain.
Any help would be great. thanks
Scott
By technofarmer
Well its finally happened, its time to replace the belt on my 2011 Polaris Sportsman 500 H.O. Is there anything specific i need to know before getting into it? Is there one brand of belt i should get over another? I'm still on my first Polaris and plan to keep it at least another 8 years.
By YamahaGrizzly
So my Yamaha grizzly 700 wasn't going into reverse for some reason but Jon and George figured it out on what to do to fix that problem for me. Jon Talks about how he was able to fix that problem my Yamaha Grizzly was having with the reverse.
On a side note we are so close to 1k subs! hell ya!
By Carl Edouard Denis
Hello to al, ,
First time poster long time ATV rider. I just go a used 2003 TRX650 got the card cleaned and it started up right away. ONly problem I am having is that its idling high. Any ideas as to wy this may be happening?
CED
By StolenATV
went to sell this guy my bike and on his test drive he just took off and never came back.
The post 2015 Yamaha YFZ450R Stolen During Test Drive appeared first on STOLEN 911.
View the full article
Similar Tagged Content
By Alois Specht
Hi there , have a KAZUMA 500 JAGUAR the rear diff is permanently locked , how can I get it out of lock just about tried everything I think, ?? . Thank you your help is appreciated.
By mrfartsalot
i have a 2001 suzuki quadmaster 500 4x4 that the primary cvt clutch is rusted on any ideas on how to get it off i want to try to reuse it if possible.
By Paul Maple
I have a 1999 Sportsman 500, it was running fine, than started to lose power in the winter, I adjusted the idle screw and away I went, than a few weeks ago it died, I have found that i am flooding the engine, compression was at 70PSI and due to the compression release mech. i assume i am good as it compared to the same PSI on a 2000 sportsman 500 i have. i cannot start the atv unless i go full throttle and it starts an runs for about 30 sec than dies, again it is flooded. i ordered a new carb off ebay as i could get one for around $40. put that in same issue, i have checked the timing, (good), valves out of adjustment i adjusted to .006 still same issue, i have found the exhaust lobe and rocker arm to have some wear, i have ordered new ones, but am looking for any other input in this area as well. would the exhaust cam and rocker arm cause the engine to flood? i have used a bore scope and the piston liner has good cross hatching still? any input would be great.
By colin james
View File 1996-2000 Polaris Sportsman 335/500 Service Manual
This is the factory service manual for the polaris sportsman 335 & 500.
You can download the section you need or download all of the chapters for the complete manual
Submitter colin james Submitted 10/19/2018 Category Polaris ATV
By colin james
