I just dug my Outlander out of The snowbank last weekend (yes we're just in the transition from Skidoo to ATV Season)
I did my spring once over and changed the oil a few days ago and noticed there was gas in it. In fact instead of 3L of used oil there was 4.5 L of liquid....
After driving for a few days (maybe only 10 - 20 km) I rechecked my oil and it smells like there is some gas in it again.
Any suggestions on where to begin my trouble shooting?
Thank you
Jeff
there is one way in for fuel from cylinders but it have to be very high mileage on the engine and u feel less torque
Are you referencing worn piston rings?
Jef_In_Arviat, do a compression test. You may be getting some blow by gases into the crank case.
The only way that I know fuel can get into the crankcase on an EFI machine is blow by. Worn rings, damaged cylinder wall, or a damaged piston will allow compression to leak by the piston and into the crankcase. In a machine as new as yours, this is not common, but still possible. Using the wrong oil, not changing the oil, not cleaning the air filter are all things that can speed up engine wear. If the machine has been neglected, things can wear down pretty quickly. I would start by doing as Ajmboy suggested, do a compression test.
    • By canamKID
      Anybody familiar with this noise from my quad? Just started.  It temporarily goes away when I attempt to shift into another gear but shifting has gotten harder too.
      20260711_150338.mp4
    • By Elk
      2002 Polaris Magnum 325
    • By Coyote251
      I am hooking up a speaker on the rear of bike and want to use a factory auxiliary switched plug and not have to cut into the factory wiring or add another switch. I have read a bunch of posts that say there should be an auxiliary 12V connector in the front and one in the rear. I found the one in the front when I hooked up my winch but cannot find any in the rear. I have seen some pictures showing one on the right side attached to the down tube behind the side cover, but there is nothing on my 2024. Can anyone confirm that there is a auxiliary 12V connector in the rear on the 2024 700 Xmr? If so, can you please tell me where it is (with a picture if possible)?
    • By Coyote251
