2009 Outlander MAX - Gas in the oil
By Coyote251
By Coyote251
service manual - 2016 Can-Am Outlander L-Series
By hporter1208
Okay, so I have a 2002 Rubicon 500…bought it last year and it sat for several months until I put a new rear axle in, FINALLY got that done and was super excited to finally have my wheeler going, just to notice a strong gas odor. Popped the seat off and sure enough, pouring gas from the carb overflow. Fast forward a few more weeks and get the new carb and get it in, no leak! Yay. Except now I have no spark. 😒 I’ve tried another plug and checked and am getting no power to the coil pack. I’ve read and read and mostly what I’ve found is ECU, which is fine…but I like to exhaust all avenues before buying the more expensive parts just because I don’t wanna spend the money and it have ended up being something simple that I overlooked because I was trying to rush. 😂 I don’t know if it’s relevant, but I read on another post that someone had similar issues with theirs and it was the sensor on the side of the carb, just a thought since this literally happened after I put the new carb on. It also displays “- -“ on the display screen where it should show the gear position.
By huntindog
Also , I have a mystery bolt That I cannot remember where it goes. M6x 70 or so. Hex head with a flat washer.I will try to attach a pic.
TIA
By Slitzer
Hi,
Thinking about to upgrade with a performance exhaust.
Appreciate tips on brands and where to buy (ship to Europe)
