Nothing special, but it is a work in progress. I'm new to the forum, but I am very active on other forums. It has Tusk Nerf Bars, IMS Pegs, Tusk Billet Gas Cap, Aluminum Stem Caps, One Ind. Bar Pad, TinyTach Tachometer/Hour Meter, Rock Bumper, Rock E-Brake Block Off, RuKind Headlight Covers, Scott Handle Bar Grips and Tusk Handguards. I have +3" a-arms and braided lines coming. Thanks, Rappy97
Okay, so after 12 hours of working at the shop, I got it, camber and what not is correct. The front is a bit lower than I would like, but it will work perfect for YFZ shocks, which are 1.5" longer.
Thanks. It is about 51" wide. Future mods include YFZ Front Shocks, 2001 Raptor 660 Rear Shock, HMF Full Exhaust, Renthal Bars, Grips, Sprockets, and Chain, HotRods 397 Stroker Kit, ModQuad Intake, QuadTech Seat Cover, GForce Axle & Rear Hubs.
I was going to get a duner YFZ, ported, FCR carb, cam... lots more (it had 65hp) but I like ice racing, which I wouldnt be able to do with it, due to a +6" swinger and a narrow axle. And, I can get into a smaller class when racing.
I just looked at your pics. Very nice bike! I like the look of the Honda fenders, esp. when they are race cut! I have had 2 Yamaha's and I beat the crap out of one, and it runs great lol. I have to push start it, and it has on flat tire, but it is super fun, since it is an 80.
Thanks! I also like the Honda fenders, they look a lot different then any of the other ones. I have a Yamaha Moto-4 225 i think its a 1986 or something? But anyways it just keeps on chugging no matter what, it makes a horrid valve ticking noise and has a bent frame but nether of those seem to matter at all. Its tons of fun!
Thank You Very Much Tagels!
Next is +4" swinger, 446 stroker, Renthal bars, GForce axle & hubs, Burgard +1 stem, stock 2010 700R SE stock tires & wheels, Elka, Fox, or Works shocks, race cut fenders, 15hp shot of N2o, HC2, K&N Clamp-On, Porting & Polishing, Oil Cooler, DP Clutch Kit, ASV levers, Trail Tech Vapor... and so on...
    • By McClaw
      I've narrowed it down to the Polaris Sportsman XP 1000 S or the Honda FourTrax Foreman 4x4 EPS
      What do you guys think?
    • By Autokill83
      Good Day, just bought a 1988 Big Bear 350 and am missing the bumper - will a bumper from a 93 with the holes in the front fit up directly? Please see the attached pictures of the bumper for reference.  any assistance would be appreciated. Thanx !
    • By TravisCr
    • By KdlH
      Hello.
      Thanks everyone,
      Kester
      new to the forum saying Hello from arizonA
