2000 Arctic Cat 300 Fouls plug and runs rough
By Gwbarm
I pulled out my Big Bear needed to do a few things probably havent been started in a year. Gassed it up charged the battery started right up. I have been using it around the property for this and that. Went to hook up my trailer to pull up to the house while it was idling it quit. Went to start it turned over but wouldnt start. After trying a few more times lost all power. Pulled it up to the house with the John Deere, the first thing i checked was the Universal fit soloenoil from Amazon and it was only a 10 AMP fuse so it does not universally fit the big bear it should be 30 AMP fuse. At the time i remember noticing it but forgot, at the time i had other problems like wiring harness being in a box stuck engine and no spark. when i bought it, yeah i know, thats one ishould have walked away from, but if i go to the trouble of hooking up my trailer and going there, its following me home.
Thats old news, i still need to check it all out see if it lost spark and see if the starter shorted out it was acting kind of sluggish, i replaced the fuse with the spare 10 amp and blew immediately. I will try a 30 and see what happens.
By Tuzz
By hardcastle
