I have a new mechanical seal ordered for this machine, I see in a lot of other threads that while I'm replacing this to replace the oil seal right behind it. Looking on bike bandit for specs I see no oil seal, just a ball bearing? Is there an oil seal there and where may I find one to order or is it the ball bearing I need to replace?
I think Gearhead is right, the oil seal should be right behind the ball bearing. I also agree with Pete's opinion to just go ahead an replace the bearing and seal since you are in there IMHO.
I did replace the mechanical seal and oil seal, runs like a champ now! Anyone tries to do this w\o a manual it is very simple to pull everything with a 2.5" drywall screw and reset with a socket for the oil seal. The mechanical i machined a piece of 2" od 1 3/8 id tube down to 1.65 to set the seal and it worked 1st shot, using a socket i busted the ceramic piece twice and had to get a new seal lol (learning expierience) Thanks everyone for the help!!
    • By Mhatayas
      What oil does everyone like to run in the older quads?
