Help a rookie out-84 big red
sledheadred
My girlfriends dad has a 84 Big Red, he bought new, it is like miont condition, all original. now he is old. So how can I tell what size the engine is?
It has reverse with low and hi range trans 4 spd autmatic.
Im not into ATV'S, im a sledhead, and gear head...trying to help a old man out.
He wants to sell it and buy something more stable like a smaller 4 wheeler.
So how can i find out engine size and value?
Thanks,
Carl:aargh:
Edited by sledheadred
misspeeled words
    • By Spritee1
      not sure where to look next
    • By HSTAR
    • By ResQ91
      Hi guys
      battery and connections good
    • By hardcastle
    • By utvboard
      2009 HONDA BIG RED
      Big Red
      KEY FEATURES
      2009 Honda Big Red in Camo
