My daughter 06 Pheonix ll onl run forabout 10 minutes befoe it sarts sputtering and finally dies, have cleaned the carb and jets 3 times and added an inline fuel filter as well as new gas. Any other ideas would be appreciated?
Have you replace the air filter? When it starts to sputter if you sray in starting fluid into the air cleaner, will it run? If it does, it is fuel starved and that carb is not working.
* Added full year and manufacturer to thread title.
  • 7 years later...
That’s a great bike the Phoenix.  Take a look inside the thumb throttle cover there’s two wires inside the cover with a plastics partition that separates the wires. Mine was worn out and causing a contact issue.  I separated the wires and the problem stopped.  It’s a rev limiter that interferes with the ignition system.
This could be your problem.
i added  this response to your topic you started as well.
Edited by Frank Angerano
    • By mehim
    • By oztrax
      MAX 4 6X6 2008
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By kevinohio
    • By Rick Shropshire
