Polaris scrambler 500 h0 4x4
pauliej
Check all your body grounds first. Meaning take every ground off and clean them first. Check the tightness of the ground bolts. Once that is done then proceed with your troubleshooting. Guessing costs money so be 100% sure. D/L a shop manual and follow their test procedures.
Mario Welding Inc
Telecommunication
and Utility Equipment
Repairs
Mario Welding Inc
Telecommunication
Repairs
l
l
I hate when I post from my company phone and forget to turn off the signature
Hello I have an issue when the battery dies all the electrical componets start to fail.I removed the batery started it ran fine but nothing turned on no lights no cooling fan nothing.I though it can run without the battery.I think I have a alternator problem.:elvis:
If you can run it with out the battery then I would think that the problem is not your alternator, as the alternator is providing the voltage to provide spark. Did your gauge cluster die before this happened? (no speedometer, and Loss of 4 wheel drive) I know the units in the 2000's had an issue with water getting into the gauge cluster, and EVERYTHING runs through that damn thing.
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By Need-help-with-quads
      Can anyone help me?
    • By HSTAR
    • By ResQ91
      Hi guys
      battery and connections good
    • By Its-always-something
