The wheeler will start and idle rough, when the throttle is applied it will bog down and die. If you start it with the lights on low or high it will run but when the lights are killed it will bog down and die. It was recently timed at top dead center and will still roughly run. CDI box? I dont know what else it could be.
    • By realpilot
    • By Elk
      2002 Polaris Magnum 325
    • By OldATVowner
    • By Rockbottom
      What should i test next?
      thanks ahead
