Bigger rachet.... What is the problem you are having? Is it stripping or just hard to take off. If you use a little heat you might warp the covers and def will ruin the gaskets. Try a lil Pblaster and let em soak for a while
Edited by marioweldinginc
at this point I would say bigger rachet/wrench. as the saying goes no replacement for displacement. That also is true for the size of your wrench. Remove as much plastic to get in there easier and get the best leverage. I would stay away from heat because its aluminum and it would warp very easy. Same reason you dont remove/install a sparkplug on a hot aluminum head. try an impact gun if available.
I work on heavy equipment and when removing pistons that are 12" in diameter we would have no problem using a 20 ft piece of pipe to gain leverage.
yes got all but one off now the motor is completely rebuilt and butting everything up tomorrow. but i have a problem, one of the header bolts striped out in the head what can i do without removing the head! help please
One of the two bolts that hold the head pipe on ?
    • By LCP92
    • By middlebrookgt
    • By DexKing
