By DexKing
Good day everyone!
I am pretty new to ATV/UTV/Small engine repairs and would like input on your absolute must-have specialty tools for maintenance and repairs. Aside from the obvious wrenches and sockets, what are some more specialty type tools you use for troubleshooting? I don't plan to open a repair shop or anything, I just do this as a hobby. Looking forward to your responses!
By BillR94
Thank you for your time
Bill
By wjmedic
Recently rebuilt front end on this Polaris 400. New axles, bearings, seals, control arm bushings, Hilliard clutch thoroughly cleaned and inspected with no damage noted.
Everything put back to together. Placed bike on jack stands all four wheels off the ground, started in 2 WD switched to AWD both front tires spinning, when AWD turned
off right front wheel will not disengage from AWD. Checked voltage at connectors both left and right connectors have no voltage with AWD switch off, and both have 12.4V
when AWD switch is turned on. Repeated turning switch on and off several times with no change in condition. I am thinking this must be something mechanical with the
Hilliard clutch on the right hub ie. weak spring or stuck rollers on the Hilliard clutch assembly (Is this a logical thought?) any ideas on trouble shooting this before I disassemble the
right front hub again
By sunn
Has anyone had experience with the installation of the Optional RH Side Panel Close Off Kit as shown as p/n 2207445 which is supposed to help control the heat on the right side on my legs? Right now that panel is wide open with excess heat on my leg.
By Maddman200
What Speciality tools will be needed besides the flywheel puller to remove and replace a crankshaft in a yamaha 700/550 engine? Is a vertical case crank shaft installer tool needed as well? Any feedback is appreciated
