The deal I got today for my quad.
By quadmaniac
By TomJulio
I recently noticed my Fourtrax 2WD has 4WD wheels installed on the front. The back spacing is significantly different than 2WD wheels and they are almost touching the strut springs and the tires actually do touch the springs.. So far, no luck locating 2WD wheels to correct this issue.
By Olchap
Hi, I am new to this forum I am currently working on my 1989 Yamaha front end. The cv axles were bad so I changed them on both sides with all new wheel bearings. Now I'm looking at the front brakes and the 2 cylinders for the brake shoes on both sides do not work at all. I am also new at working on brakes so its a mystery to me what needs to be done to fix the cylinders. Can somebody please help me with these brake issues? See the image below.
Thank you,
Olchap
By Gwbarm
I pulled out my Big Bear needed to do a few things probably havent been started in a year. Gassed it up charged the battery started right up. I have been using it around the property for this and that. Went to hook up my trailer to pull up to the house while it was idling it quit. Went to start it turned over but wouldnt start. After trying a few more times lost all power. Pulled it up to the house with the John Deere, the first thing i checked was the Universal fit soloenoil from Amazon and it was only a 10 AMP fuse so it does not universally fit the big bear it should be 30 AMP fuse. At the time i remember noticing it but forgot, at the time i had other problems like wiring harness being in a box stuck engine and no spark. when i bought it, yeah i know, thats one ishould have walked away from, but if i go to the trouble of hooking up my trailer and going there, its following me home.
Thats old news, i still need to check it all out see if it lost spark and see if the starter shorted out it was acting kind of sluggish, i replaced the fuse with the spare 10 amp and blew immediately. I will try a 30 and see what happens.
