I have been working on this atv for a few weeks. It had several issues and I"m down to the last one and its kicking my butt. New ecu ( customer got it and the dealer says its an early 06 model ecu and I should have a later). But the atv had this problem with the old ecu as well. I replaced the ecu, harness, new fuel pump, used harness in very good shape. Replaced throttle body with all sensors and injector at once. Checked valves, and timing. No FI codes, tps is adjusted. New spark plug ( spark is great ) I pulled the throttle body off and held it in my hand while turning the engine over and the injector wet my hand with fuel within a few cranks. The problem is the atv does not want to start, if you pour a little fuel down the throttle body it starts up and runs. It will usually start for the rest of the day, but it seems to run lean. The atv does have a K & N filter and exhaust on it. I called power commander and checked several other piggy back systems, but none of them add fuel at start up. I know the ecu being the wrong one could be causing this problem, but I find it hard to believe since the atv does run good once you get it started. The original problem was a bad harness ground causing the ecu to burn out, plus it had been sank so when I switched it over I cleaned every relay and plug on it. I have been through the manual and checked everything that would make the atv run in limp mode and it all checks out. This was just a precaution, as once its started it does not go to limp mode. I keep the battery charged and also give a 40 amp boost when cranking on it. What am I over looking?
is the temp sensor bad ? had a problem like that on an injected yamaha and the temp sensor was bad and didnt give enough fuel for a cold start .... you can also check the wires for the temp system... thats the only thing i can think of on it ... ill look in some shop manuals and see if i can find any thing else...
I didn"t dip and ohm out the tempature, but I do know that when I first got it it had a high idle problem, like 3000 rpms and within a few minutes the temp light came on ( same as fi ). I will pull it and clean it to be sure its reading correctly though. Thank you for the reply, anything you can think of Ill try. I have just flat run out of ideas.
no prob ... i have worked on alot of quads an have a small shop ... but thats all i can come up with on it .. i know the temp system on some determine how much fuel is injected .. the comp adjusts the fuel pulse on the injector depending on temp ...
Yeah I used to own a small shop, now I do trouble shooting and engine work for a couple of local shops. So you can imagine what I looks like now working on this thing on and off for 3 weeks. I will pull the sensor tomorrow. I already told them I need the right ecu, since the customer bought his own he needs to come up with a little 500 dollars to make that happen, and I have a feeling hes going to pay and pick up. I would really like to figure this out though, its one of the tougher problems I have ever had, minus electrical problems of course, lol.
This project had got put on the back burner. I asked another mechanic I know to take a look at it and he said fuel pressure is down. I stuck the line in a 12 ounce water bottle and it took about 3 seconds till 4 ounces of the bottle. Also once your done trying to start the atv you if you disconnect the fuel line there is no pressure. Im going to replace the fuel pump, but I still intend to pull the sensor because it seems you all are right. Thats the only item that can really affect the air fuel ratio without setting off the f.i. light. I will post the final find.
Well after replacing the fuel pump, and pressure valve to the tank there is no change. Im going to pull the sensor tomorrow and clean it. ohm it out and take one more shot at it. If its not the temp sensor the last suspect would be the ecu. Although I just find it hard to believe since the atv had the problem with the old ecu. But there were two ecu models put out in 06. Although Im pretty sure the numbers just had to do with the recall.
Hi, new to this forum but this seems like the exact same issue my buddy is having with his 06 king quad. No cold start. We haven't been out for a while then this winter we went to go on a poker run and it wouldn't run. Threw it on a charger and even off the boost it wouldn't start. Put some de-icer in it and still no go. It will go with a shot of Quick Start in the throttle body and then runs fine. If it sits for any length of time it needs this little shot to fire up. His ecu was upgraded from the previous owner. As far as the temp sensor went we threw it in a heated shop over night and still wouldnt start on its own. Definetly was warmed up to what it would have been in the spring. Always ran great before and no issues. Really interested it what you might think since the problem is really similar.
well after replacing everything you could possibly think of. Checking valves down to stator I finally gave up and just unplugged the air pressure sensor. without the vacuum running the idle is a little low but only dies once warmed up. This atv has a filter and pipe so Im going to add a power commander to fix the lean issue once running, however after much research the power commander does not have a fuel additive during starting. What I found is that the problem is a lean issue. All the atvs have it, but it seems some of them get so bad that it does not receive enough fuel to start.
I haven't checked over the quad in detail but I think I will start buy pulling the plug and see how it's running as you mentioned the lean running condition. We put a pipe on it a couple months back and he had no programmer so we ran it for a bit on a new plug then pulled it and observed it being pretty greyish white. I was very surprised and told my buddy there was no way to run it like that without a programmer. So we removed it and put the stock one back on. We did install a snorkel kit in which we modified the air box to allowing a ton more air in versus stock before we had tried the exhaust. Going by what you say of them being fairly lean I have a pretty good feeling that just may be our issue.
Thanks for the info.
Well so far I've pulled the pump and cleaned the tank and screen. Everything was pretty good but I had it tore down that far so might as well. Refilled with fresh high test gas and still the same. I pulled the injector and with the lines all hooked up there is no initial spray when u first turn the bike on while the pump is running. Once you start to actually start the bike then it sprays fuel. Is this normal to only spray once trying to start?
its the valves, they are shim and bucket valves, after 500 miles brand new they need to be checked but depending on abuse by 5000-7000 miles they need to be re-shimmed, im currently working on one myself with the same problem but saw the white spark plug and adjust the throttle position sensor to let in more fuel and that wasnt the issue now im just looking for a valve clearance chart for this quad and stumbled upon your thread.
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By jeffrocdx
    • By Asand211
      I've got a 1995 220 Bayou and the electric start does not work.  When I got it the machine was pretty rough but I was told it ran less than a year ago.  The key switch had been cut off and wires  twisted after the key was lost.  I bought a new ignition switch and repaired the wiring and it is working correctly.  It is in neutral and the neutral light is on when the key is turned on but I get nothing when pressing the start button.  I verified there is no voltage going to the starter from the solenoid.  The fuse in the solenoid is good.  Something I found that is odd is that I get positive voltage(12 volts) to the brown, black, and white wires that run into the solenoid when the key is on.  That doesn't make sense to me but I could be wrong.  I would appreciate any help I can get. Thank you in advance.
    • By alexwv1863
      I'm currently working on an 04 Suzuki Eiger 400 and ran into some issues. Main issue being it's really hard to start. Once I get it started, it runs bad. Sounds like it's missing, which I'm pretty sure is an idle issue. It's not my 4 wheeler. I'm working on it for a buddy. Someone started working on the original carb and 2 jets were missing when I got it to work on.
      So, I ordered a new carb. To get it to run, I had to adjust the throttle screw on the handle bar almost all of the way out. Even doing that, it still sounds like it's bogging down and missing.
      I did put a gas filter on it, which I'm questioning whether or not that's the issue and it's not getting enough gas like it should. The petcock only has an On, Reserve, and Prime option. It also has 2 ports. I guess I have the hoses hooked up right. There's no way to shut the gas off completely, and also it looks like there's no gas getting thru unless I run it on Prime. Reserve drips gas. I'm going to take it apart today and clean it. I'm also going to take the jets I need out of the new carb and put in the old one.
      I don't know what all this person did you the 4 wheeler before I got it. There's odds and ends missing that I've noticed so far. What else can I try or look for? What could be the gas issue with the carb and petcock? The carb was completely off the bike except hanging onto the throttle cable. The diagram I found for the carb doesn't help me with hose placements. Any help, or questions would be appreciated. I can attach photos if it would be of help.
