Hoping someone can help point me in the right direction . Engine starts and runs but only with the choke on fully.when you open the choke the motor wants to die and you have to keep giving it gas and it starts to back fire.Went through the carb. once but that doesn't mean I didn't miss something .so if someone could point me in the right direction.Thanks
If you went thru and cleaned the carb maybe it is something else. Did the diaphram seat properly?
Either not enough fuel or too much air. Check the intake boot from the airbox to the carb and make sure it is secure and not cracked. Some people spray a mist of starter fluid around the carb while it is running and see if the rpms change.
Just rechecked the boot between the carb. and air box. Sure enough there is a small tear ,will order new part and go through the carb. again and repost hopefully this was the problem.Now I just have to wait by the mail box.
No still waiting for replacement parts.I had to order the parts on line.Local dealers don't seem to carry alot of parts inventory.But then again thats alot of money sitting on the shelf.
Good luck, keep us posted!
Update.Replaced boot between carb. and air box replaced pilot jet screw recleaned the carb.meaning I disassembled everything cleaned with carb. cleaner and compressed air. Runs good now .thanks for your ideas.
    • By digrig
      Hey everyone,
    • By BillR94
      Thank you for your time
      Bill
    • By Jason39
      I’m having a issue with my choke when its on it runs fine when I cut the choke off the atv cuts off went to take the carburetor off and saw the choke plunger broke at the nut to screw it in could this be my issue? Do I just need to buy a plunger kit and put it on? I took the carburetor off and cleaned both jets anyway just to make sure and it’s still having issues staying on
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
    • By jatho
      What is the best engine oil to use for the Suzuki King Quad - also any other tips and tricks I should know before doing an oil change on these bikes
