Phrase Connection
Guest Fox300exchic
Guest Fox300exchic
Rules: A person says an expression or phrase, and the next person needs to say another expression or phrase that contains at least one word from the previous expression or phrase.
May your life be like toilet paper...long and useful!!
    • By Spritee1
      not sure where to look next
    • By hardcastle
    • By CaptJim
      Hello guys, I hope I am not invading your space, but as you can see the current state of my project here it's not but about 50% ATV. I am hoping that some one here can point me to a wiring schematic that I can reference since the "Complete wiring harness" i purchased from Amazon did not include a diagram of any kind.
      The ones that I am finding on line vary greatly but none show the connections for the separate 5 wire connector coming from the motor.
      Can someone tell me where these wires go?
      Thanks in advance for all help!
    • By Mhatayas
    • By Werewolf
