Hey guys,
A friend dropped off his late 80's Big Bear 350 for me to give it a once over. You know, oils's, brakes and grease. I thought I was done with the bike when I noticed a pool of oil under the bike. It looked like it was coming from the clutch cover. It looks like someone has worked in the clutch before because of all of the sloppy blue silicone around the cover.
Now my questions since i dont have a manual are..
1) Can I just remove the cover and not have to worry about pieces of the drivetrain falling out?
2) Is there a gasket, do I need a gasket or can i just clean and re-silicone?
3) I noticed a clutch adjuster on the cover, do I need to do anything to it before I remove the cover or or just leave it alone?
I've not worked on too many Yamaha's before so any help would be appreciated!
Thanks Rich
So i found the problem. The bottom left hand bolt the one thats about 3" long was wrong. Who ever replaced the clutch must have lost the bolt in question and replaced it with a different (Wrong Size) bolt. Instead of using a metric fine thread bolt the dumb as* use a standard 1/4 thread bolt that was too short. They cross threaded the bolt so bad that it never tightened down on the cover, thus causing the leak.
I drilled and tapped the hole and replaced the bolt so all should be good now.
I was able to save and clean the gasket that was on the cover and I used the blue gasket silicone to seal it. I'm going to wait till tomorrow to refill the bike with oil.
    • By Rick Shropshire
      I’m looking at replacing rear brake calipers on both of my blasters. I was told that the only thing available was a hydraulic upgrade? I’d prefer the original. Anyone?
      I decided it was time to do the brakes on the Eiger, i got it a couple of years ago and worked out all the bugs got it running good and ignored the brakes. None on it ,front or rear. Decided to attack the front first no pressure on the master cylinder and screws were stripped out on the reservoir, took the banjo bolt loose and pure water ran out, glad i didnt wast time on drilling the screws out, pads were shot also. Pulled a couple out of my box o parts. One was for right hand so wouldnt work, the other looked fine until i opened the reservoir and full of white powder. Cleaned it out anyway and tried it, only would build up a minimal amount of pressure. So no go on that one. So ordered new master cylinder and pads, so now i have to hurry up and wait.
      On to the back they are drum brakes so i knew this would be fun, 20 year old machines that have been mudded and abused for that length of time nothing comes off easily. The engage shaft was froze solid from corrosion. Getting that out is easy but you have to get to it first.
      The center nut was supposed to be 30mm but it wasnt it was 27 the only size not in my large set, go figure,
      The previous owner decided it was a good idea to JB Weld the cover on making it near impossible to get off, had to chiesel it off.
      The mounting plate was a different story, nut was tight tight tight took my biggest impact two or 3 times hammering on it to get it loose after soaking all night in PB Blaster. Got it moving along the splined shaft easily but wouldnt come off, when it got to end of its run it would just stop, ended up using 2 24 inch pry bars one on each side, past the point of being gentle and it finally came off.
      Got to the drum and it came off easily a little suprised at that, it was full of mud and rust, i knew it was going to be bad because there was a snorkle on it when i got it, never buy one with a snorkle, they are highly abused to the machines limit, but i got it cheap .
      Finally got in there and no shoes left and a complete mess.
      Lots of mess to clean up.
      Got it looking a little better.
      Lots of cleanup later! Waiting for new parts.
    • By Kawiherder
      It starts and runs Ok but after a while the temp gage lights up and the fan fails to start.  Any suggestions on where to start looking would be helpful.  Thanks
    • By Doublewidekings
      I am looking for what you would consider the best ATV winch for under $125.  Thanks in advance.
    • By Cobra_kai83
      The gas in the tank was bad so I drained it and put new fuel in. It still wouldn't run so I took the carb out and cleaned it. Re-installed the carb and now it will only start and run under full throttle. It also runs rough like this. The engine stops running once I back out to 1/4 throttle. What the heck is going on?
