Anyone ever deal with balistics batteries? They look like the ticket for me
I also use a schumacker trickle charger
Wow now thats a cool battery
8 Cell EVO 2
Dimensions: 112MM (L) x 60MM (W) x 103MM (H)
Positive Terminal Location: Left
Weight: 825 grams (1.81 lb)
Voltage (Charged): 13.6V
Amperage: 15 Pbeq A/H
Cold Cranking Amps: 275 CCA
Operating Environment: -18°C (0°F) to 60°C (140°F)
Typical Applications: 1000cc and under multi-cylinder motorcycles and 450cc singles.
8 Cell EVO2 (100-011) - $159.99
I been doing some research and I haven't been able to find too many reviews on using this battery on ATV's and Winching.
I swear by the Odyssey batteries.
I had one in a old standup jetski that lasted a good 10 years under unspeakable abuse. Full discharges, floodings, and full salt water shorts.
They also have near no internal discharge do they can be left alone without a battery maintainer for seasons on end and will still be ready to go when needed.
They are expensive, but so worth it.
8 Cell EVO 2
They might be a newe company but the specs on the batteries are awesome. an 8 cell battery weighs only 2lbs!
I hope this isn't considering a hijack of the thread.....
But someone mentioned using a trickle charge on the battery...
Is the necessary?
What qualifies for if it is necessary? The length between rides and/or the temperatures in the area?
Sent from my DROID X2 using Tapatalk
It all depends on the temperatures and parasitic draw. It's best to remove the battery and store it somewhere where it will be warm. Also lead acid batteries (wet cell) have internal draw that happens all the time, so they will discharge themselves and it gets worse with age.
It's a good idea to put them in the garage and on a tender every so often during winter. This also keeps the electronics in your quad from draining them. At the very least, disconnect the negitive terminal before leaving it be for long periods of time then charge it before you use it again.
    • By mehim
    • By logray
    • By oztrax
      MAX 4 6X6 2008
