1st 2012 Ride
Crow Canyon is a 400 acre riding area that has a nice MX track with a lot woods and hills to ride. Not very many legal riding spots open yet in Ohio. We are having unseasonably warm weather here in Ohio. It was 88 degrees yesterday.
Here is the only picture I took with my cell.
nice, nice !! i'm full of envy, still in the 30's & 40's here and snow :laugh:
i can't wait for a day like that here !!! :yes:
The one thing I am missing is a good snow picture. I had this idea to jump over a flaming snowman, but my quad is either broken or the snow melts before I can get time to go riding. :aargh:
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By mga
    • By mga
    • By NZrider
