Finely got to ride!
By BenJammin
By cavry
Wiring shows White and Brown to solenoid blades. Then a black wire from starter circuit relay to solenoid. I am confused, where is that black wire supposed to connect?
Thanks for any help
Cavry
By hardcastle
By Louznmemind
By Its-always-something
