The 500 H.O. EFI is a machine to be reckoned with. With 54% more power than Honda Rubicon 500, and even 22% more than the new-for-2006 Polaris Sportsman 500 EFI, you can expect class-leading power, handling and performance every time you get on. Plus, it has all the great Outlander features, such as, Visco-Lok automatic front differential, SST frame, TTI rear suspension and more. - [bombardier]
Includes everything on the Outlander 500 H.O. EFI, specifically designed for two riders. XT added-value package includes all the extra equipment you want - factory-installed.
MAX-specific features:
Customized chassis with proactive riding position for passenger
Ergonomic passenger backrest
Multi-position passenger handgrips
Raised passenger floorboards
Convertible Rack/Seat system [CRS] with totable box
Ability to ride with passenger or ne-up with added gear
XT model features:
Cast aluminum rims
2,500-pound [1,134 kg] BRP XL2500 winch by Warn‡
Roller fairlead
Handlebar and wired remote winch controls
Aggressive tread Carlisle‡ ACT radial tires
Heavy-duty front and rear bumpers
Handguards
2007 Bombardier Outlander Max 500 H.O. EFI XT
    • By Adamb2025
    • By umax33
      can someone tell me which side the neutral and reverse switch are on a 1986 honda trx 200 The service manual does not say which side, i got the lites pulled out and looked at them and i think the switches are bad. i just don't know which side they are on , the photo in the book just shows how it looks after a cover is off and not which side its on.i would just like to know so i don't have to take stuff off that i don't have to.  thanks for any info on this.......
    • By oxidized_black
    • By umax33
      i just got a 1986 honda trx 200 and the reverse and neutral lights don't work, i looked in the service manual and it says to remove two screws and the cover comes up and you can check the bulbs, the book does not show the two screws and i can't see them.Does anyone know how to get to the screws to check the bulbs. i will appreciate any help i can get...thank you
    • By Thekevinjb
      thanks
