I picked up a new baby last Saturday and I haven't stopped thinking about it since. Its an '86 atc250r with a title. I'm the 4th owner of it and it only has one rebuild (stock), fmf pipe, dg silencer, and k&n filter. Wondering how much it should be worth? I'll tell the price after a few replies :biggrin::cute:
800 to 1000 around here !!
Depending on whether the buyer or seller was more motivated that day, that R would change hands for between $900-$1100 here in the Pacific Northwest. As a trike nut, I keep my eye on these and it's about a thousand dollar bike anywhere you go these days.
Edited by Senator
    • By kevinohio
    • By Joeguy
      Did a top end rebuild, honed .010 over, new piston, rings, valve seals, etc. When i re assembled i only had like 30 psi of compression but then after it sat all night i now it seems to have gained some somehow, there is much more resistance pulling it over and i even got it to fire for a few pops. Issue i got is that it makes a loud squeak noise through the intake i believe (goes away when throttled so something with carb area) and it seems to not want to run well. I took head cover back off and timing seems fine so im not sure if something is sticky and that's why i got some change over time or maybe the valve lash is messed up after doing all this, i did get another cam for it but i wouldnt think it would make enough difference to need to re lash. Any insight on next step would be appreciated, i will be looking up how to do lash on these because it is a very weird angle to slip a feeler gauge in.
      Actually cam is slightly off now that i look at the picture, thought it was good while looking in person. Hmm.
    • By Rick Shropshire
    • By Ejwill
