Been having trouble getting this quad to run. when its in neutral the reverse light is on too and will only start if you hold the reverse overide button and will run but only if you hold the starter button on while running soon as you let off either button it dies, and to start again you have to turn the ignition off and then back on. Also, wont have spark unless its in that gear but when it fires up it creeps backwards. if you jiggle the shifter (auto) and get the neutral light on it wont have spark only if the reverse and neutral light is on and you hold the override button down will it pop off. Any ideas anyone this is driving me crazy!
Look above in this form for my post on extracting and printing schematics. There is a link for where you can get the service manual and wiring diagram for free.
From your description of the problem I would suspect one of the diodes in your fuse block is either blown out or shorted out. (maybe one is in backwards?)
Mike
    • By realpilot
    • By logray
      Hi all,
    • By OldATVowner
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
