im not sure what the problem is i think its the solenoid but this is my first atv so not totally sure. i was riding it just fine for half hour or so then stopped for a second and it died. i lost all power lights indicator lights....everything. i thought it was the battery so i cleaned the terminals and reconnected everything. i had power after that but when i hit the starter all it did was click once then the power was gone again. i let it sit for a bit and the N light came on so i tried it again and it just clicked once and power was gone again. i threw the battery on the charger and it said it was fully charged. im not sure what else it could be other than the solenoid so i need some help to know if the problem is deeper.
I'd suspect that a bad connection let the battery voltage drop down too bad levels. ( not charging.) I've said it here before, just because the voltage seems ok doesn't mean the battery has the amperage to do it's job. I'd let it charge overnight & if that doesn't change anything then go searching for other problems. Bad connection somewhere? Stator not charging?.....things of that nature. The way you describe it, it sounds like a dying/dead battery. The battery might regain a "surface charge" on it's own but really needs a deeep charge to get back to proper capacity.
I charged the battery all day and hooked it up after work and that didnt work. I took the relay in and had it checked and was told it was fine. My next test i jumped it to make sure it wasnt the starter and it jumped fine. My thinking now is the battery has fused cells which is giving me the false complete charge.
I'm a betting man....& id bet 10:1 that you have a battery failure. If it ran fine with a jumper battery then that tells me all the electrics are functional. If you need to check further with a new battery check the voltage with it shut off ( 11.5-12.5 volts) then check it with the engine running. It should be around 14.4-15 volts. If it's near 16-17, then i'd worry that the regulator might be bad and it boiled out the battery. Like OB said, check the regulator if it's overcharging. Is the battery still full of electrolyte?
i got a new battery got it charged and put it in and it started right up then i shut it off hooked it up to the charger and got a read out of 13.1 turned it on and got 14.9-15.3 so i think its safe to say it was just the battery and the charging system is working fine. thanks for everyone's help and input it was greatly appreciated
    • By quadnut20
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
    • By quadnut20
      What a great week to ride !! Im semi retired and plan on riding this week !! Who else is riding and where !!
