got a 2011 linhai 4 wheeler that shuts down after about a mile and then will not crank for several hours anybody got a solution?:aargh:
If it won't crank it sounds like the battery is going dead. Check your connections and test the charging system. If it re-cranks and fires up after a few hours i'd assume the battery is pretty healthy, just not getting charged.
    • By Arizona
    • By dalton7545
    • By DaleJAM
    • By Hagbard
      Have a long story that I'll attempt to make brief. I picked up what was advertised as a 1987 LT230E with no cam or valve cover, harness dangling, no plastics, and all kinds of slop in every bushing and bearing, but hey, it was free and I love a challenge. Local guy had a couple 87 230E motors he was selling on craigslist, picked up one of those and a pisspounded DG RCM and header for $100. Went through the harness to start sorting things out and noticed a few key differences, like the stator connectors didn't mate up, one round and one square. Rubbed some of the grime off and found a VIN, Lo and behold - I have a 1990 LT160E, not a 1987 230E... By the grace of who knows what, the 230 just so happened to mount up directly to the 160 frame with no mods. Wasn't until I had broken the seal on starting to chase down the harness leads that I found out.
      As it stood, advertised as a 1987 230E
      After a bit of elbow grease and some eBay raiding.
      Made a new seat cover and found a set of plastics, New carrier bearings, and brakes all around.
      Pulled the steering and front suspension all apart and gave it some love with new bushings and tie rods
      Ordered a small fortune in NOS and China parts from eBay and RockyMountain and after a couple weeks of wrenching and soldering I have a nearly complete wheeler, in pretty decent shape. Cleaned up a Mikuni carb I had laying around and mounted it up with a cone filter and a Lowe's Racing™ intake boot, and fed it some gas, primed the carb and tugged on the started rope a few times, and sure enough it belkched out some soot and fired up, ran for a couple seconds and died. No sputter, just shut off. Checked for fuel startvation, vacuum in the tank, no problems there, plenty of gas in the carb. Suspected clogged air jets, so I pulled it out of the boot and gave it a shot of ether, and it did the same thing, fired up, ran strong for 2-3 seconds and shut off. Then suspected I f*%#ed up the wiring harness somewhere, and re-traced all the leads with my newly colored wiring diagram, thanks to my kiddo's Crayola marker collection, and everything looked good. Started to suspect the CDI, solenoid, or coil might be faulty and was flipping thru the manual when a buddy stopped by with a pair of boat seats for me to reupholster for him.
      He's a little bit of a savant with engines and electronics, and he got curious when I told him my predicament. Three minutes later he said "Hand me a pair of needlenose?" which he used to short the neutral switch to ground, and had me give it another tug. Fired up and ran great, no shutting off, so we deduced that the neutral switch must be at fault and after he left, I pulled it off to troubleshoot, and decided to flick the shifter a couple times with it off to see the little nubbin go around in a cricle. It didn't. I should mention at this point that I had previously changed the oil and while doing so, I took the opportunity to adjust the clutch without consulting the manual because I'm the dumbest guy I know. I did it according to the procedure I had learned for the LT185 I have, and figured the adjuster itself looked the same, they must be the same thing. I loosened the 10mm lock nut, and started turning the adjsuter screw clockwise waiting to encounter resistance, and then back it off 1/8 turn. I was really surprised when it kept turning and turning, but figured it must have been WAY out of adjustment, and went on with business. Figured I might need clutch plates at some point.
      Encountered this problem, and actually read the manual and the procedure is entirely different, and I realized that I had basically "adjusted" it into oblivion. I have since drained the oil and tried to re-adjust it twice, with no luck. Anyone have any idea what I can or should do to correct the issue, or am I missing something else entirely here? (chain is off and sprocket nut is loose, if that makes any difference.) Any insight or advice would be appreciated, thanks.
    • By WHALErn
      I ordered an ATV through ElectriRide a ( Pioneer 1500w Power E-Grizzly Electric ATV ), on February 13, 2024.  They ( ElectriRide ), ordered it from the manufacture on February 28, 2024. Not sure when it shipped, but it arrive here at my house on June 25, 2024.  I live in Hawaii.
      Unpacking it, I quickly became aware that this was not the ATV that I ordered.  The package had some damaged, but not major.  After unpacking it, it was very obvious that this was not the ATV that I had ordered, plus it was missing some a number of parts, namely the rear rack & no instruction or electrical circuit layout, just to name a few.  A couple of days later I found ( 2 ) small two burnt holes in the upper frame, right side, also.  Several days later I tried to charge the batteries on the ATV, after plugging it in for over 4  hours, “NO CHARGE” , I checked the charger’s output voltage, it read “ “ 0 “ volts, the charger needs to be replaced also.
      The next day, I reported all of this to ElectriRide, & they asked for photos, which I later that day send to them.  They said they would look into it and get back to me. For the last 2 1/2 weeks, I have been calling them (playing phone tag ) & emailing them, basically getting the same message back from them.  They sent me e-mails “ we will get back to you “ or “ Please rest assured that we are committed to resolving this matter to your satisfaction. “.  As of today, that message was 10 day ago, and it’s been 3 weeks after receiving the wrong ATV.  And 5 months from the time of ordering the ATV.
      The ATV that this looks the most similar/closest to the one that I received is the ( Pioneer 48v 1000w Adult ATV Electric ) in their catalog, but there are a number of differences to it also.  ( Mostly it’s a 1000 watts motor, not a 1500 watts motor ATV, plus a number of other things also ).  The suspension & wheels are completely different, along with some of the electrical components, and it was missing the rear rack also.  Along with some other minor things.
      I seem to be getting nowhere with communicating with them, (ElectriRide ) in getting this mix-up / changes resolved after calling / emailing them pretty much daily for over 3+ weeks, I am turning to you, the ATV community for any suggestions for helping me to solve my problem.
      Please leave any suggestion / ideas, you thing might help me solve this problem, or who to contact that might be able to help..
