Hey everyone! I hope someone can help me out.
I have a 95 LT-F4WDX that I have been having a strange problem with. It starts & idles perfectly but when I try to rev it up it spits & sputters. I found about 2 weeks ago that when I turned the switch to "headlights on" it ran fine. That worked for a few days but then I had to position the beam selector switch in the middle of high/low beam for it to run right. That worked for about two days, now it must be on low beam & it has to warm up for about 15 - 20 minutes before it will run ok. When switched to high beam, the lights go out & it dies. It seems to me like it needs to have a load to keep running right.
Anyone have any ideas?
Thanks!
Well I took the entire body off and went through every wire I could find and they all look good. Took apart and cleaned all connections and it still does the same thing. A friend said it could be the voltage regulator. Thoughts on this? Could a faulty regulator cause symptoms like this?
Thanks!
Sounds like you have some wire chaffing going on start chasing wires and cleaning conections you will find it. print off a wiring scematic.
Ok, apparently a voltage regulator/rectifier can cause this?
I checked the battery voltage with the key off & it read 14.5. I turned the key on but not the bike & it slowly dropped to 12.8 and stayed. When I started the bike it immediatly shot up to 19+ volts. I unhooked the regulator/recitifier, started the bike and it read a steady 13.4 & seemed to rev up and run fine.
OK, just wanted to confirm that the voltage regulator was the problem. I put on a new one & everything is fine! Well, I have to replace the taillight & headlight bulbs (they dont seem to like 19+ volts too much) but other than that everything seems fine.
    • By crankin
    • By ButchM
    • By Callaway
    • By dkgg5755
    • By harryjr
      hello everybody my name is Harry jr and i recently picked up a 90's Yamaha moto4 225 i beleive and neede a starter was all he said ( i know right ) thats what they all say
      anyway i picked up a starter and installed it and when it is crankling it sounds as if it is not turning over freely as i9f there was a one way bearing not worrking correctly so pulled with recoil and it pulled back so hard i ripped out of my hand so hard it actually hurt now i have pulled and kicked a lot of bikes and such but never felt anything quite like this you can hear it try and fire and kick back but still acts as though somthing holding it back does that make any sense to anybody is it flywheel key , or valves wauyout any help would be great i picked tow of these up for $100 and tring to fix so we can ride as a family thank you in advance.
