Hi, I am new to this forum I am currently working on my 1989 Yamaha front end. The cv axles were bad so I changed them on both sides with all new wheel bearings. Now I'm looking at the front brakes and the 2 cylinders for the brake shoes on both sides do not work at all. I am also new at working on brakes so its a mystery to me what needs to be done to fix the cylinders. Can somebody please help me with these brake issues? See the image below.
Thank you,
Olchap
I have a 2022 Kymco MXU150 and have been trying to bleed the rear brakes for several days. I have used a vacuum and also tried the lever pumping. i took the caliper off and compressed the piston with a C clamp and had a tight brake lever. I put it back together and still cannot build any pressure in the brake system. Any ideas from anyone? Thank you
Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
