ok i got a honda foutrax trx 300 4x4 1998 for free the guy i got it from sunk it and it has ben setting up for a while what all do i need to do to get the motor to run i got spark and all electricall parts working and has compression but im not shure the exact amout of compression maybe valve adjustment??
ok i will change the oil and the gas tank is all dryed up but for now i just have a go cart gas tank on it cause all i realy wanna know is how bad off the motor is and i did put some gas in the spark plug hole it hit one time but im thinking the carb is stoped up so it dosnt have enough fuel to go through i will look at that this weekend and see what happens thanks for the help
thanks for reply i realy am just seing what exactly i can do with this engine just to atleast get it crank one time i got it for free and realy dont want to spend the money to get a new engine but i am glad u did mention clutch and throttle body i havent even looked at that yet thanks for the help
Hopefully you wont need to change the guts, but you never know. I would try and change the oil and gas. I've sunk many atvs, but if they are not dried for a while, it could be an issue.
I've hydro-locked my pistons and had to remove the spark plugs then crank it to remove the water. But still good afterwards! :yes:
Well i did get the motor to crank for a minute but i just thru gas in the slark plug Hole i still need to clean the carb out real good and possibly order a rebuild kit for it but it will crank every now and then im guessing fuel issue but im not shure and motor looks good it didnt look bad at all
    • By 88bigbear
    • By Cj Winds
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
