Similar Tagged Content
By Brent Mason
I have worked about 4 weeks on my Griz600 and have burnt 2 CDIs up ! I added a wire harness and stator and It starts but runs erratically like spark timing is off ! So I would like to try another CDI but I don’t want to Pay an arm n leg ! Anybody have one ? Thanks
By Brent Mason
I have been trying to get my Griz600 running right for 3 weeks ! Grandsons used it and it quit running , no spark ! New stator etc and started but ran terrible ! Found a burnt capacitor on cdi . Installed used cdi and burnt it also but ran same as other cdi . Came to conclusion wire harness had short so stripped it and found some bad spots fixed and another cdi ran terrible again ! Bought another harness and same rough running ! Checked spark timing with light (put tdc mark on case and on pull start hub) and when it starts timing right on but will jump 25+° retard ! When timing is on tdc marks it has no power ! The stator is new but I am wondering if the pickup coil is triggering incorrectly ? Also had top end apart when I first started having trouble and although rings were good I installed new rings . Also new timing chain and check the valves , they were good also . It kind of seems to boil down to the last stator I installed new ? I have done trouble shooting on quite a few cars , trucks , dirt bikes and ATVs but this is frustrating me ! Just wondering if anyone has any ideas ? Carb was new last yr and I checked it ! I
IMG_4379.MOV -
By Brent Mason
IMG_4272.MOV Originally had my griz600 stop running and then wouldn’t start ! After testing all coils , valve lash , compression (115psi) and all tested ok I bought a used cdi . After cdi install it still wouldn’t start (no spark) ! So even though the stator , pulse/trigger and charge coils check within good range I decided to switch the stator etc ! It started but It is very unresponsive on throttle and acts like it is running in 2 Different spark timing ! With slight throttle it will take off good but instantly go into a very different running mode with no power like timing very retarded but it will switch back to running good for short period then bad again ! Since I replaced the stator and it started I then decided to install the cdi I replaced and it did the same thing ! Also I noticed the Used cdi I Took off had a capacitor that had swelled and extruded from the back of the cdi . I had always heard and I believed that when these CDIs go bad they machine will quit and will not run . Is that true ? I also checked the cam/valve timing and its ok ! Checked with timing light and it does fluctuate on idle ! I am thinking I have 2 bad CDIs . I also switched the trigger Coil wires and would not start then . Man , this thing ran good before and I am confused ! Video below may help !
IMG_4272.MOV -
By Brent Mason
1998 Grizzly600 ! Slowly died then wouldn’t start ! All coils check good ohms ! Checked ac voltage from source coil get OL ! Is the source coil bad ?
By Aj Hurtibise
Hey guys I'm new to the Forum I just got a 2000 Honda trx90 looking to make it go a little bit quicker I don't know much about four wheelers but I am a technician at a dealership so I know my way around a motor.
Similar Topics
By Susan Makowski-DeGraw
My quad runs, it starts up runs for about 10 minutes and then it dies if you let it sit for 10 minutes it’ll start back up ride for another 10 minutes and then die again, trying to figure out why it keeps stalling
By NoahJakavi
Hello i have a linhai 300 of the 2004+- era. I had a cluch problem so we changed it. After changing it has a hard time to start going. When you pop it into gear and press the gas it barely drives but when it starts going about 20km/h it start driving well the acceleration is normal and everything do you have any idea of what could be the problem
By VikingTrad3r
picked up my third timberwolf 250 for my daughters. these are great light weight little quads.
have a strange one for you. the quad will NOT start in neutral. it will start in first.
if i lift up on the gear selector just enough to hear the little click (its not loud, sounds like a contact clicking, perhaps the neutral safety switch?) the light will go out, but it won't yet be in first either. that is how i have shown my daughter to start it and she can.
id like to carry out whatever repair is needed. i have the pdf of the shop manual but it doesn't really have a flow through diagram.
any help appreciated! thank you.
i need to add something. it feels like i can switch into another gear BELOW neutral.
so if i switch to neutral, i can keep pushing the gear selector, and it has another click below the neutral. the light stays on, and when i pull up into first it kind of feels like it has two positions it moves through to arrive at first.
By texaskaw
fighting this thing for a month now.No spark at plug.
New ignition coil,pick up coil,stator,reg/rectifier,all new wiring.Started it up today rode for an hour shut it off.Tried to start later wont start.pulled plug wire it firing a blue spark while starter button is pressed.Tried new plug no change. It stared a couple times an ran for few seconds then died.Will CDI act this way? The reg/rectifier get pretty hot is this normal?
By cody75
2016 sportsman 450ho cranks. Good spark, removed injector getting fuel no check engine light no start
