Similar Tagged Content
By ryan93
my atv and the internet are telling me two different tire sizes that are way off and need help figuring it out..PLEASE HELPP
By auburnfan327
I have a 2007 Honda Recon ES and need some new tires. The stock tire sizes are 22x10-9 and 22x7-11. I'm looking at some Carlisle AT489 tires but the closest sizes i can find are 22x10-10 and 22x7-12. Will they fit? Thanks.
By rockwell16
great tire brands Green ball ,ITP, Maxxis and bighorn
(GREAT NEWS ON A 2X4 YOU CAN MIX TIRE ON THE FRONT AND BACK LET ME EXPLAIN THAT MORE BACK TIRES LETS SAY YOU GO WITH THE GREEN BALL SPARTACUS TIRES ON THE BACK YOU CAN GO WITH THE MAXXIS X PATTERN FRONT TIRES CANT DO THAT ON A 4X4
By WhiteMooseHunter
I have a quad (Can-Am) that takes 25 inch tires, just got a set of rims with tires that are 26's, not a whole bunch taller, don't see any problems using them? My main question, just in case I want to swap the tires in the rims, is on the rear tires.
My original tires are 25/11/12 the replacement rims, the tires are 26/10/12. If the rims have the 26/10's now, will it work with the 25/11 tires? They appear to be the same width, are they? How can I tell what will work on the rim.
Inside the rim, it is stamped 12/7.5 ET:+51
By labs3557
I bought some stock wheels and tire that came off a Honda Foreman i believe. My problem is the rear rubbs my exhaust.
Should I just put in a spacer and move the whole thing out an inch or two? Or should I buy 2 new wheels that have the correct backing?
I have a 96 Fourtrax 300. the wheels that were on it are 9X9.0AT the new ones are 11X7.5AT.
Similar Topics
By Sha35297
Customer brought in this bike for no response when put in gear. After getting into the transmission I found the main shaft for the clutch had been stripped where the gears mesh up and also the shaft for the gears had been broken in half. I replaced all broken parts and reassembled the transmission. Now it makes a knocking noise in low gear and in reverse. When in neutral it tries to roll reverse while making the same knocking noise. I’ve disassembled and reassembled it several times with the same result. Any ideas??
By Josh Cornelius
just rebuilt the carbs because it sat up for a few years and wouldn't run at all. now it idles, but only with choke. you can give it just a little throttle but not much before it tries to die, take choke off, it dies (warm or cold temp). air fuel mixture doesn't really effect it at all and it'll still idle with mixture screws all the way in. any help/ideas would be greatly appreciated!
By ed1228
Having a problem on my 2006 400. LCD display will not power up. Check fuses under seat seem ok. Is there any inline fuses I should know about....Any help?
By Curtis01
OK, sooo I finally did the old skid plate and screen removal to clean out my oil sump during an oil change... This bike only has a couple thousand miles on it. Runs like a top still... Very few issues over the years after buying it used.
But boy I wasn't expecting to see this! Piece of a circlip, stuck up in the screen, and a another shard of metal and maybe a piece of gasket material. Nothing in the oil but that... Pristine otherwise, and still runs like a top. Always has.
Soooo, is it a wrist pin clip? That's the only thing I can think of like this that could end up in there. But definitely wanted to throw it out to guys that have seen the innerds of these more than I have.
The valves on this thing are still within the factory spec even. Been a really good lil workhorse...
Any other ideas?
