Similar Tagged Content
By gyminis
axle trade,what are the options. I want to lengthen all 4 axles on a 1996 suzuki 4x4 king quad. my question is are all or most models of axles interchangeable?????????????? if not ill accept any information on the same:wink:
By BecSneed913
I bought a 2002 Polaris Sportsman 700 twin 4x4. after purchasing it, i realized there was quite a bit of slack where the axles go into the front gearbox. Dont know if this normal or how to get the old axles out of the front gearbox. Would be thankful for any help.
By YFZ450
i have an 06 yfz and i was wondering will a 04 axle work in my 06 with my 06-08 carrier bearing
Similar Topics
By Roy Anderson
I have had a 2002 Suzuki King Quad 500 for almost a year. This is a question I’ve posted before, but likely missed the answer due to being new to the site. Here’s the issue. When in 4 wheel drive, especially in low range, especially when pulling a load downhill, I hear a lot of clanking in the front end. As if the front drive shaft was binding then unbinding. A friend who had a 1987 Dodge 4x4, told me all the noise his front end made when in 4 wheel drive was entirely normal. So, is this something I should worry about? I have all the bodywork and tank off right now doing a valve adjustment and carb rebuild. If I gotta do something, I’d like to do it now. Lastly, I’d love to find a carb tuning guide for this era of Mikuni. Haven’t tracked one down yet. Any thoughts of where to find one? Great forum. Have really enjoyed it so far.
By BillyBlast01
Hey everyone, here is an update. I have my new atv battery in and it's fully charged and installed. I have my new hi/lo range knob in that was missing. The ignition is the original one so my new OEM switch will be in Thursday or Friday. I have an original LT-F230 service manual. It gives all the colors of all the wires but does not say which are hot and which are ground. Here are pics of the front cover and the wiring page. Can anyone lead me in the right direction? I want to see if I have fire to the ignition switch.
I do have a multi meter
By BuckBilly
By Lellwyn Griffin
Both the red wire and the blue have power with out the start button being pushed. Which one should have power? When I hooked up a positive and a negative to the starter relay it started.
