Hey all, from SW Virginia here. I just picked up a '01 Bombardier Quest 650 on the cheap (seller couldn't get it to start). After correctly plumbing the fuel pump (new pump the prior owner installed but had the hoses going backwards lol) and cleaning the carb and fuel tank, repaired all the batt - and batt+ connections she lives!! I had swore to the wife unit I wouldn't be dragging another "project" home but I couldn't pass it up, it had new tires, new starter, new fuel pump and low hrs. All's good after she took it for a ride! 😆 It rides like a tank, very stable and tons of power.
I also have a magnum 4x4 that I am working on it is getting a new piston, In the tear down I pulled off the flywheel
and found that all the magnets are not attached? why does this happen? there all in good shape so is it possible
to reattach them to the flywheel? I can buy a different flywheel, but it looks like around $300 or more and one of them on Ebay
looks like the spacing is off a little so it may have the same issue.
the stator looks good also
