By p5200
By kawasig
I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
By rgeiser
just wondering if i pay the thirty dollars how soon will i be able to access the manuals?
By Otter9099
I have a 1996 Suzuki Quad Runner 250 LT-4WD. What tools should keep on the atv at all times incase of break down for a trail fix? Share what you carry and share pictures if you can.
By RamzV
We have multiple riders in our group, looking for more people to ride with. I am also a certified powersport tech so if anyone needs any work done look up Neptune powersports on fb
