PM returned, I pasted here for anyone else who is curious:
I don't have too much experience with manuals but I would see if highlifter or someone else makes better plates. Also I know with the wet clutch in the newer models, the type of oil you run makes a huge diffrence. It does have to be wet clutch safe. I a not sure about your setup or if it is even a wet clutch.
Read a forum thread on arctichat.com from a guy running 29.5" tires on a 400 and he liked this clutch kit.
EBC Brakes - Clutch kits
DRC120
DESCRIPTION: Complete DRC Series
FITMENT:
•Arctic Cat
◦400, 2003-2004 - 2x4
◦400, 2003-2008 - 4x4
EBC Brakes EBC COMPLETE CLUTCH KITS from ATVUnlimited Brakes Atv&pos=3
EBC DRC Series Complete Clutch Kit - BikeBandit.com
[ame=http://www.amazon.com/EBC-DRC-Series-Clutch-DRC120/dp/B000GVA5WQ]Amazon.com: EBC DRC Series Clutch Kit DRC120: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/518QMEZzSkL.@@AMEPARAM@@518QMEZzSkL[/ame]
EBC DRC Series Clutch Kit DRC120 Suzuki | eBay
Almost forgot, you'll need the CT 006 tool or an equivalent.
[ame=http://www.amazon.com/gp/product/B0041CDTXI/ref=pd_lpo_k2_dp_sr_2?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B00A43TO5K&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=13F78Q625XPR8W1K0E37]Amazon.com: EBC Clutch Removal Tool CT006: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/31egsPa-2-L.@@AMEPARAM@@31egsPa-2-L[/ame]
http://www.ebay.com/itm/EBC-CT-Clutch-Tool-Arctic-Cat-400-2x4-4x4-2003-2004-/390527912457?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item5aed470a09
Edited by catcandu
added tool link
    • By cavry
      Cavry
    • By logray
      Hi all,
    • By tepin
    • By Shorty51
