The mud hole won over & over I made a video but can't get the thing to load. It turned into a winch test! But it was 1 bad day for me and the GoPro camera ran out of space on the memory card and what I got I can't share. My buddy laughed at me because I didn't wont to give up but I kept getting the quad bottomed out!
It's the GoPro Hero Earthmover. CK thats fixable and I have thought about it but I'm not sure how it would handle too lift it and put bigger tires it's very few times I have needed more ground clearance. I have rutted out the mud hole pretty good. I was counting on the power to get me thru it!
a friend has 1 with 27 inch mud lites and a 2 inch lift an his wheels are 1 inch dider than stock an it does pretty damn good ..another friend has the prairie 700 and he is running 29 inch tires and aftermarket 2 inch wider wheels and the 2 inch lift with a clutch kit and full exhaust system.. and it screams through the mudd...lol.
Hey! hanging have you done the firmware up dates for the gpro. I have a Gpro and the last fware update I (my daughter) did expanded the memory card capability to i think 8gig and made a big change to the video itself. If you watch these two videos you can see the difference for your self. Tell me what you think?
Firmware up date
[ame=http://www.youtube.com/watch?v=OCQwXWQsAGw]Honda Rincon In The River Don @ Bowen - YouTube[/ame]
standard firmware
[ame=http://www.youtube.com/watch?v=qc485V3Nz7o]The Fine Sand Pit. - YouTube[/ame]
I have not updated mine till now I'm going too! To my eyeballs the updated video looked better brighter color & more detail. I have had mine for a year but only used it around 6 or 7 times at the most. Have you used yours under water it's pretty cool to do? Thank you for the update info.
I have another waterproof vid cam also I've used that under water but not the gopro
[ame=http://www.youtube.com/watch?v=q8_KT5o0jJo]The fish tank - YouTube[/ame]
Create an account
Register a new account
Sign in
Sign In Now
    • By PvtTarget
      Will not go into 1st but if ya go past will go into maybe next gear. Will not shift into reverse. I have see others say that the shift cam assembly dowel worn or fall out. How do I get to this? Do I need to break case in half?
      thanks for your help
    • By DaleJAM
    • By qcm413
      Hi,
      thank in advance
    • By DaveswMN
      Thanks for any thoughts.
    • By Pure_Michigan
      Hello everyone.  This is a Go Cart and not a typical "ATV" but it has an engine so I'm hoping someone can help me.  It's a Helix FTX with a Manco 150cc engine.  The engine will start and idle for awhile, but will not take even a small touch of throttle.  Stalls.  It seems to take throttle and rev up when you first start it cold, but in just a minute, it will not take any throttle.  I've replaced the Fuel valve/Pump on the fuel tank with no joy.  It's a nice little cart, but without a workable engine, it's a boat anchor.  I'm not dumb when it comes to small engines, but this one has me stumped.  I'm running out of options.
      I'll mention that while it is idling, it will sort of "cough" every 6 or 8 seconds and then recover and idle again.  Eventually one of those "coughs" causes it to stall.  It will start back up pretty easily, but as I said, it absolutely will not take any throttle and then it will cough and stall a minute later.  I thought it could be timing, but there is no "adjustment" for timing on this engine.  I downloaded the user manual and it mentions nothing about timing and is pretty much useless as a service guide.  It just shows the basics.  I'm attaching the manual so you can get an idea of the machine I'm dealing with.
      Any input would be greatly appreciated.
      Kind regards,
      Don
      Manco-Helix-6150-150cc-Owners-Manual.pdf
