The mud hole won over & over I made a video but can't get the thing to load. It turned into a winch test! But it was 1 bad day for me and the GoPro camera ran out of space on the memory card and what I got I can't share. My buddy laughed at me because I didn't wont to give up but I kept getting the quad bottomed out!
It's the GoPro Hero Earthmover. CK thats fixable and I have thought about it but I'm not sure how it would handle too lift it and put bigger tires it's very few times I have needed more ground clearance. I have rutted out the mud hole pretty good. I was counting on the power to get me thru it!
a friend has 1 with 27 inch mud lites and a 2 inch lift an his wheels are 1 inch dider than stock an it does pretty damn good ..another friend has the prairie 700 and he is running 29 inch tires and aftermarket 2 inch wider wheels and the 2 inch lift with a clutch kit and full exhaust system.. and it screams through the mudd...lol.
Hey! hanging have you done the firmware up dates for the gpro. I have a Gpro and the last fware update I (my daughter) did expanded the memory card capability to i think 8gig and made a big change to the video itself. If you watch these two videos you can see the difference for your self. Tell me what you think?
Firmware up date
[ame=http://www.youtube.com/watch?v=OCQwXWQsAGw]Honda Rincon In The River Don @ Bowen - YouTube[/ame]
standard firmware
[ame=http://www.youtube.com/watch?v=qc485V3Nz7o]The Fine Sand Pit. - YouTube[/ame]
I have not updated mine till now I'm going too! To my eyeballs the updated video looked better brighter color & more detail. I have had mine for a year but only used it around 6 or 7 times at the most. Have you used yours under water it's pretty cool to do? Thank you for the update info.
I have another waterproof vid cam also I've used that under water but not the gopro
[ame=http://www.youtube.com/watch?v=q8_KT5o0jJo]The fish tank - YouTube[/ame]
    • By mikeexplorer
    • By Tim Keiper
    • By Panupong Pradchaphet
    • By Whiterabbit
      3500lb, synthetic rope lead and everything needed to install for........................................ $89 bucks!  I'm installing one on my '01 Bombardier Quest and it looks like a legit buy. If you have a RK nearby & you need a winch you might want to swing by before they disappear.
    • By DayBreakJim
      20230725_171507.mp4
