hi guys im brand new to this site an need a little help.
i bought a used 04 warrior.so i bought a new barnett clutch.installed it
put it all back together.and it started ran fine i pulled in the clutch and put it in gear
and it took off like the clutch was let out. i adjusted the cable and the handle. no effect either way new clutch cable and clutch lever assembly. can somebody give me a tip
please
please
metal, fiber, metal, fiber, make sure they are staggered. And when you install all new plates, you are gonna need to adjust the linkage! Look in your book and adjust the linkage to specs. Your new clutch SHOULD have come with complete instructions from Barnett...also, if you have AutoZone motor oil in it, drain it out right now! and go get the proper oil from Yamaha. It costs more but car oil has additives that will shorten the life of that expensive clutch you just bought. Let us know if you cant figure it out
Edited by Raptor8
grammar
yeah its got yamalube 10-40 in it. im almost 100 percent sure they are right. the barnett kit i got instructions just read to soak the plates for 30 min before installing them. it had no other instructions with it. called barnett the guy said the small plates are first and last plate
Is the small plate the metal ones? I'm almost positive the fiber/friction plate is first and last. This thread seems to back me up. According to some of the posters there are two plates that are different from the rest...they go first and last. If you give me a plate count of each plate (both fiber/friction and metal) I'll tell you which one goes first.
http://forum.dirtrider.com/discussion/8234642/first-time-to-replace-clutch-kit-in-yz85/p1
It's been about 20 years since I have been inside of a bike gearbox!
Back in the day we used to clean the plates with mineral spirits and sand them with fine paper to get a "new" friction surface on them. If the basket had wear we would remove it and file the edges down where the fiber plates would hit the basket and notch it. This was a cheap fix for a worn basket and clutch. We also use to put washers under the clutch springs to stiffen them up so that a worn clutch would grab better.
Edited by gaquad
    • By tflack500tbx
      Background,
      Any Ideas?
    • By quadnut20
    • By kevinohio
      Any body have a part number for replacing the safety interlock on the left brake so you can start the engine with the brake handle pulled and in gear
      or how to bypass this function so you can start in gear
    • By Gtc4d
      Thanks.
      Todd
