Ok letting this unknown atv sit overnight it started and ran for 15 sec or so. So this should mean valve spec is ok set at .003, electrics work, why would an overnight rest do this? Yesterday I was getting spark, fuel into carb and to the cyl, so what gives?
  • 5 years later...
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By TomJulio
    • By LCP92
