I have a 07 artic cat 500 4x4,
The dash started flashing " VOLT" and after a few minutes the entire dash goes blank.
Any suggestion what it might be?
Thz in advance
  • 4 months later...
I have to same problem with my 2007 Artic Cat. Except mine the screen goes blank and EFI starts flashing and won't start back for about 5-10 minutes. Any advice please. Replaced battery 3 times this year already
    • By crankin
    • By Arizona
    • By toe420
    • By Baldwin007
      I was wondering if anyone out there has a digital copy of an Owners Manual for a 2003 Suzuki 500 Vinson 4x4? I have a service manual, but no Owners Manual. I would like to know how to correctly operate/engage various features.
    • By BillR94
