By OldATVowner
By Rockbottom
any ideas how to correct
By T37Mark
By Kurt Reiser
My quad will not run with the airbox hooked up Will not go past quarter throttle as soon as you unhook the tube at the back of the carburetor it runs great does anybody have any ideas what it could be I have a bad fuel pump one on the way can that cause the quad to run like that
By hunky
Thanks for looking!
