Went winter rid'in last Saturday, the 18th. It rained like a SOB all nite & it was still rain'in to beat the band when I left the house at 0500 for the ride (Yeah, I like to leave early). :coffee:
It was 31 degs F when I unloaded the bike, and Yup, it was snow'in ... it was just try'in at first but later on, it was do'in pretty good. :woot:
I tried to get off on the snow a couple times, but it was soft & deep & I didn't feel like digg'in or winch'in ... so I turned around to ride at a lower elevation (7000 ft instead of the 9000 ft where I was) ... and the bike was clean up to that point .... sigh .... and I was also dry !! :cool:
Yes, my expensive rain suit bibs leaked !! I'll bet I don't have a dozen rides with these & they leak. I think it must be from the rubbing of the material (Gore-Tex) on the seat while riding !!?? :wiggle:
So I stuff a sweat shirt in my bibs (probably looked like I was carry'in a load, if ya know what I mean !! :smilielol5c: ) ... and I rode another 15 miles. At that point I stopped at a Forest Service shack that had an overhang porch, had some lunch, & put my other rain pants on underneath the bibs ... and rode another 30 miles. But I'm pissed !! :aargh:
Here's some photo's .... :seeyac:
Sweet pics Gunny !!! :yes: Its snowing here up above 9000` WOW People are still skiing here !!
THANKS Quad Guy !! :notworthy:
I know, heck, kinda wish I still had my tracks on !! :woot:
Very nice pics Gunny !!
I am glad someone else is getting snow, finally nice here after 7 months of the white stuff !!
Thanks OX !! 7 months ?? WOW, that is a long winter !! :shocked:
    • By mywifeknowseverythin
      For those of you who are into coffee, I found this little article that might interest some of you.
      I admit it. I am a coffee snob. I try not to be obnoxious about it, but let the record show: I enjoy a really great cup of coffee. But pay $4 a cup for it? No way. Even snobs have their limits.
      Over the years, I’ve learned that a really good cup of coffee has less to do with money and more to do with knowledge and care. In fact—and this is the amazing thing—the more I learn, the less I spend.
      BEANS. Purchase whole bean coffee as soon after it has been roasted as possible. Freshness is the key to a superb cup of coffee. Purchase in small amounts—only as much as you can use within 2 weeks of being roasted.
      RATIO. The perfect ratio of coffee beans (prior to grinding) and water is: One-half cup whole beans to 8 cups of water.
      GRIND. Grind your beans as close to brew time as possible. A burr or mill grinder that crushes the beans is preferable to a blade grinder that cuts them. Once ground, coffee should be used immediately.
      WATER. If your water is highly chlorinated use bottled or filtered water. It must be right at 200 F, just short of boiling temperature, when it hits the dry grinds. This is critical to creating a great cup of coffee. Consume immediately.
      STORE. The enemies of roasted coffee beans are air, moisture, heat and light—in that order. Keep your beans in an airtight container that is not close to moisture (sink, dishwasher), heat (oven, stove) or light (countertop). Do not store your daily coffee in the refrigerator or freezer because contact with moisture causes it to deteriorate. For larger quantities of roasted beans that you cannot use within 2 weeks, wrap in airtight bags and store for up to a month in the freezer—making sure the beans are completely protected against moisture. Once removed from the freezer, do not return.
      BUY. Most supermarkets offer high-quality, roasted coffee beans for $.60 to $1 per ounce ($9.50 - $16.00 per pound). Ouch! Discount warehouse clubs like Costco, Sam’s and B.J.’s have considerably less expensive coffee at about $9 a pound for name brands like Starbuck’s and Peet’s. Still, that’s too rich for my blood.
      ROAST. I roast my own coffee for two reasons: It is infinitely better tasting and half the price. I purchase green coffee beans by mail order for about $4 - $6 a pound, depending on current conditions and variety. I started out roasting in a popcorn popper (West Bend’s Poppery II is ideal) and have graduated to a small coffee roaster. My favorite resource for everything from roasting instructions to green coffee beans is http://www.u-roast-em.com/. Owner Jim Cameron has a wealth of knowledge and is anxious to share.
      You won’t believe how easy it is to roast coffee. And enjoyable, too. I roast only one-week’s worth at a time—about twenty minutes. Green coffee beans have an indefinite, useful shelf life of at least a year, and probably two or longer. But I’ll never know. Coffee beans just don’t last that long around my house!
    • By qcm413
      Hi,
      thank in advance
    • By Topendcol
      First issue was fuel pump wont start once ignition has been turned on. Replaced the pump as I had one on hand, than noticed no power so replaced the fuel pump relay as that was were i traced the power to. Still nothing so further inspection looks like signal is coming from the PCM (FLR B20) but not switching the the brown wire to the fuel pump. Ive checked the operation of the bank angle sensor and it appears operational. Fuses and wiring all appear OK. The engine stop relay also tests OK. Ive been through the repair manual and diagrams but to no avail. Fully stumped, any tips would be helpful. Thanks
      Col
    • By Mikael
      I recently bought and old Kazuma Dingo 150cc and to begin with it started just fine. Then, for no apparent reason, it wouldn't start. It turns the motor but fuel isn't getting to the spark plug.
      As mentioned in the title I've since replaced the fuel filter, the carburetor, the ignition coil and the spark plug. Fuel comes into the carburetor but seems to go no further. Is it a vacuum problem? Does anyone have a good idea about how I could diagnose the problem? And how to fix it?
      I don't know what year it's from, sorry.
      Sincerely
      Mikael
    • By Sycoholic
      No clue what that seat fits... The fenders are in pretty good shape. I will be removing the black flares from them though to put back on my other Polaris. $100 gets everything but those black fender flares/mud flaps. Local pickup in Asheville, NC. Not trying to kill myself trying to package these, just pass along a good deal.
